RCU Forums - View Single Post - Setup and throttle cable placement
Old 02-01-2013 | 05:30 AM
goirish's Avatar
goirish
Default RE: Setup and throttle cable placement
ORIGINAL: ec121
Don't use a servo for the choke. Run a rod out the bottom of the cowl or out the front. To get a better run at the carb. use a flexible Goldenrod type pushrod. Put a longer arm on the choke and carb. I make mine out of aluminum scrap.
Why are you saying don't use a servo for the choke?
