RCU Forums - View Single Post - Setup and throttle cable placement
Old 02-01-2013 | 11:40 AM
ec121
Default RE: Setup and throttle cable placement
I use my throttle trim to shut down the engine. One butterfly is as good as the next for shutting down the engine. The JR 9303 transmitter has a slider on the throttle trim instead of a digital trim. My old 72 Mhz Hitec Flash 5X has a kill button that takes all the trim out of the throttle to kill the engine and goes back to the normal setting when you let it go.
