RCU Forums - View Single Post - Rich, Lean, Needle Valves?
Old 09-16-2003 | 09:21 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Rich, Lean, Needle Valves?
1 An engine wants to run with a 15% mixture of air and fuel. So (Approximately) 85% air to 15% fuel. If there's too much fuel, the mixture is "Rich", not enought fuel and the mixture is "Lean".
Note: Running an engine Lean can cause damage!
2 As you close the needle valve, the mixture will lean out from its present state, and it will go up in RPM. Once it peaks, back it off a few clicks. Then, point the nose of the plane straight up. There should be a slight increase in RPM. If the RPM goes down, it is too lean.
3 A Needle valve is just that... A needle that goes into a hole to adjust the fuel flow (See Pic)
4 They are probably just listening for anything unusual
5&6 There are mant factors that determine the "target" RPM. Engine size, prop size, type of flying you do etc.
