RCU Forums - View Single Post - help needed for DLE30 rear corb
Old 02-11-2013 | 12:52 AM
johnsmith122
Default help needed for DLE30 rear corb
Hi every one here,
i m new to the Gas engines. yesterday i was trying to break in the Dle 30 n have some issues wanna discuss it n get help.
i install the engine on the yak 54 by Pilot rc.
i start engine n its start very easily the problem is while i was break in the very first tank on the ground my engine stops all of sudden re start it n it stop again in some time did this for 4 to 5 time n every time engine stops but take long time then comparing every previous time.
i did not change the needle sitting from the factory setting. its the same at 1.5 turn both high n low
some one on the field who was already fly lots of gaser told me ur low end needle is rich make it little lean n he close it then reopen it to 1.2 turn only engine is smooth at low end too .
now the questions is it okey with this setting or do i need to make it rich both as i just born one full tank out of the engine half on ground n half on air with less then 50% throttle.
now next Sunday i will do that again but with ur recommendation.
