RCU Forums - View Single Post - help needed for DLE30 rear corb
Old 02-11-2013 | 01:25 AM
rfbenn
Default RE: help needed for DLE30 rear corb
Check that the plug cap is on completely, if you can see the hex section on the plug it's not fully on. They are really tight, the engine vibration could be breaking the connection,if not that maybe some dirt in the carb .
If you haven't already done so dump the DLE plug and fit an NGK CM6
Rob
