RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 09-16-2003 | 12:58 PM
  #1418
Baron UK
Default RE: Capiche 50
Luke.
Colin aka DAD!!
If you fly it with your cg (as noted at the Freestyles) and those kinda throws!!!!
It will end in tears. TRUST ME!!!
Make sure you are REAL happy with your switches this time!!
Take off on low rate. Get comfy and sorted then try the "Burty Big Bannana stuff" and get used to switching between the two. I found dropping out of high rate very hard at first because 9 out of 10 times I was completely stalled and on massive throws!!
You must learn to power up get forward speed and hit lower rates all at the same time. [:-]
Good luck Malc
