RCU Forums - View Single Post - colored sealer before covering
Old 02-12-2013 | 05:51 PM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: colored sealer before covering
With a sealer under the covering, your covering may not stick as well and or may not stick at all. Also you will have troubles if you lift your covering to make adjustments, your sealer might stick to the covering and ruin it. They do make a Product called Balsarite that is designed to make your covering stick better to the wood, but even that takes some getting used to. Good Luck, Dave
