RE: SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
Hey Adrian, I will give you a call assuming I can find your number on your website.
Meanwhile, a follow-up question on those 1/4-32 ignition shrouds. I assume if they are already welded, they already must have the wire installed. So what is the method for connecting them to the existing wire on an ignition module? I don't need to tell you the wire exiting an ignition module cannot be replaced. It is potted in place.
