Philly, yes it is... begs the question why go through all that bother... just buy the decal set !
unfortunatly the sticker sheet doesn't contain the FedEx logos, or the IS logos at the correct size and colours, other wise i would of had one.
Sprink, when did you buy your kit? after i did mine and reported it the CNC wing parts where cut over lenght to allow for the printing variances. same variance might have also pushed your ribs out a fraction causing the wobble. personaly i'd like to see little tabs on the bottom of the ribs, front and rear, which meet the plan so the ribs are perfectly lined up.. sheet the top of the wing, then turn over, cut off the tabs and sheet the bottom. Just makes sure the wing had no warps anywhere.
