RE: Servo Equivalents
I hope this helps
JR8711
Digital 2.36 oz 1.58×0.82×1.56 in 4.8V: 4.8V: ? (add) Single Bearing Metal $139.99
(66.9 g) (40.1×20.8×39.6 mm) 347.0 oz-in (25.0 kg-cm) 0.19 sec/60°
6.0V: 6.0V:
403.0 oz-in (29.0 kg-cm) 0.15 sec/60°
Futaba S9075SB Digital S.Bus Prog $149.97
FUTM0455
Volts Torque Speed
6.0V 425 oz-in (30.6 kg-cm) 0.14 sec/60°
spacer
Dimensions Weight
1-5/8 x 13/16 x 1-1/2 in
(41 x 21 x 37 mm) 2.5 oz (71 g)
JR8411
Digital 2.03 oz 1.54×0.75×1.36 in 4.8V: 4.8V: Coreless Dual Bearings Metal $114.99
(57.5 g) (39.1×19.1×34.5 mm) 155.0 oz-in (11.2 kg-cm) 0.18 sec/60°
6.0V: 6.0V:
188.0 oz-in (13.5 kg-cm) 0.15 sec/60°
S9074SB Digital S.Bus Prog $124.98
FUTM0454
Volts Torque Speed
6.0V 278 oz-in (20.0 kg-cm) 0.17 sec/60°
Dimensions Weight
1-9/16 x 13/16 x 1-7/16 in
(40 x 20 x 37 mm) 2.2 oz (63 g)
Alan
