RE: THUNDER TIGER FOUR STROKE
There are several causes for this but the most common one is that the engine is running too lean, as when you tilt the nose up or put the plane in a climb, as you point out.
Try making it a bit richer and also check for restrictions in the fuel line (which would make it lean, if you never re-adjusted the HSN).
Just my $.02
Bob
