RCU Forums - View Single Post - Homelite 25cc electronic ignition conversion question.
Old 02-23-2013 | 09:37 PM
av8tor1977's Avatar
av8tor1977
Default RE: Homelite 25cc electronic ignition conversion question.
Yeah; www.wackerengines.com, www.lambertsrc.com, or www.carrprecision.com.
The prop hub for the CDI electronic ignition replaces the heavy magneto flywheel. A sensor is mounted on a large diameter hose clamp that clamps to the front bearing snout of the crankcase, and you can rotate it to set the timing.
I made the parts for my Homelite engine shown in the pics. Just posted them to let you get the idea how it works.
AV8TOR
ID:	1855522   Click image for larger version
