RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
I have seen in some past sections of this thread, that you should run the low end a little rich. This helps in the idle coming down and may help you in dead stick when you try and throttle up on overshoot. I have this engine with ign #4 and have the initial idle set at somewhat below 1800. I don't have any issue. Yes it does take some time to idle down, but not that long.
Bruce
