RCU Forums - View Single Post - Warbird Downthrust
Old 02-26-2013 | 03:02 PM
Me410
Default RE: Warbird Downthrust
I can't change anything on the actual motor firewall and mount holes. At least not without a ton of work. I made the firewall very heavy duty using a one inch thick piece of hardwood plus extra plywood, big blind nuts all epoxy in on the back side of the thick firewall. All super heavy i know, but I knew I would need extra nose wieght, and turns out I still need to add about a LB of lead. The heavy firewall will also help to absorb some engine vibration from the G62.
Alittle downthrust could be accomplished with two washers.
I suspect the incedence of the wing has alot to do with the need for downthrust on a warbird?
More pos incedence, more downthrust ????
Don't know
