RCU Forums - View Single Post - Question on balancing plane
Old 02-28-2013 | 02:03 AM
bikerbc
Default RE: Question on balancing plane
I have never worried about the weight difference between props and it hasn't got me into trouble so far...I guess it must make a difference though...You are starting out with the lightest prop so you won't get your self into trouble when you switch to a prop that's a tiny bit heavier . If you were flying a aircraft that was already tail heavy and you went to a lighter prop I could see where that might cause a problem...
