RCU Forums - View Single Post - Warbird Downthrust
Old 03-02-2013 | 10:24 AM
Chad Veich
My Feedback: (60)
Default RE: Warbird Downthrust
ORIGINAL: Me410
I have made a shim and I will try the downthrust on the maiden flight, that may be this month if weather amd field conditions are good.
I need to try to measure how many degrees this shim wil give me, two degrees is what I hope to get.
I will post the results.
Glad to hear your Hellcat flies great Chad.
Tom
Good luck with it Tom. Unless you end up with rediculous amounts of downthrust I don't think you will have any problems. Certainly not any that will jeopardize the airplane during test flights. I had a Sea Fury which had excessive downthrust and the only time it was a problem was in a go-around situation as it would pull the nose down when full power was applied. Had to be quick on the up elevator if you were very close to the ground to prevent it from skipping the main gear. However, it was probably the best point rolling warbird I've ever flown and I've often wondered if the excessive down thrust wasn't one of the reasons for that!
