RCU Forums - View Single Post - Has anyone got the flap dial o work on AFP??
Old 09-17-2003 | 11:16 AM
Tspin's Avatar
Tspin
Default RE: Has anyone got the flap dial o work on AFP??
Hi Ian
Go to aircraft controls and select radio, properties and then look for nozzle rotation near the bottom. Now move your flap knob (that should be channel 6) you will see red bars move, look to your right and make sure that it’s cannel 6. If it’s not 6 then see what it is. You need to set channel 6 or? To the right of the nozzle rotation spot.
Paul
