Has anyone got the flap dial o work on AFP??
hi all
I have AFP and im really happy with it, its tought me to do loads of thing which i can now do at the field!
but...... yesterday i got the first expansien pack
and i like pondering around with the harrier, i usually have the flaps/nozzels on the buttons 2 and 8 (on the num pad) but i want them on the flap dial on the top of my futaba FF6 (6exa), i tried this but i wont work, any idias???
Ian
and i like pondering around with the harrier, i usually have the flaps/nozzels on the buttons 2 and 8 (on the num pad) but i want them on the flap dial on the top of my futaba FF6 (6exa), i tried this but i wont work, any idias???Thanks
Ian
Hi Ian
Go to aircraft controls and select radio, properties and then look for nozzle rotation near the bottom. Now move your flap knob (that should be channel 6) you will see red bars move, look to your right and make sure that it’s cannel 6. If it’s not 6 then see what it is. You need to set channel 6 or? To the right of the nozzle rotation spot.
Paul
Paul
Yes, it does. Click on "Controls." Click on new. CHOOSE "RADIO" or "Tx" IN THE LOWER LEFT CORNER OF THE SCREEN. Then do as Tspin suggested and you will see your flap knob make a red bar go across the screen.
Mike: the thing is it wont recognise either channels 5-6. the red bar deosent even appear, far less move
i'll try again tonite
