RE: DeHavilland Mosquito
RC universe was down and would not load pic's seems to be working now and real fast. The first pic is the plug with first layer glassing the second is the initial plug without glassing. Once I get it finished and primed will try and do a plug for more and show how I mount it without external screws... Hatem ! Working on the rudder now and will be doing the battery tray and it lookes like it will be mounted in the nose as that
gives me more foreward positioning than behind each motor. Photo also of were I moved the servo tray to and being glued in the picture. The inside of the canopy area I have the servos covered with a lite box that will simulate the aircraft radio installation. Will add a photo when it is primed as will look better. Has anyone done removable outer wing panels and how did you do it ? Thanks.
