RCU Forums - View Single Post - Prop Mounting
Old 03-04-2013 | 05:05 PM
GaryHarris's Avatar
GaryHarris
Default RE: Prop Mounting
I just went through the same thing Josh with the same engine and props. Your going to need a reamer. Don't use a drill bit because they don't make round holes believe it or not. You can end up off center and out of balance. You manual should say what size you need.
http://www.horizonhobby.com/pdf/SAIT...der_Manual.pdf
