RE: Prop Mounting
Well it sounds like an order for a reamer is upcoming. Thanks for the replies. Another question now. One of the props I messed up earlier I drilled out and put on the plane for balancing purposes only (putting everything on and in position to balance before I cover). With the tricycle config on the Kadet LT40 and the 12x6 prop I only have like 3/4"-1" of clearance from the tip of the prop to the ground. Is that cutting it close? Should I go for the 11x8 that Saito says the 56 will swing? Kinda scares me only have an inch of clearance between the prop and Terra Firma.
Thanks!
Josh
