RCU Forums - View Single Post - GAS/GLOW HOW TO....
Old 03-05-2013 | 12:11 PM
  #523
av8tor1977's Avatar
av8tor1977
Default RE: GAS/GLOW HOW TO....
ORIGINAL: SkyPilot101
Av8tor, did you use CDI on your 36cc fourmix? If so, it would be great to see a pic of the conversion. I'd like to do my 32cc and am guessing your 36 is very simular. Thank you
Sorry these pics took a while. Stihl 36cc Four Mix with electronic ignition. (The 32's and 36's look identical from the outside.) I used one of the round style sensors like CH Ignitions used to have. If you can't buy them, you can make them from an RCEXL sensor, some tubing and some glue.
One could probably just mount an angle bracket of some type off the crankcase screw, but I think my way looks better. I made that piece of aluminum block to go in between two crankcase webs, bolted it there, and then drilled and tapped that block to hold a home made sensor tube bracket.
The pics embarrass me a bit because of the rust. I live near the beach and the salt air here is like "acid"!!!
AV8TOR
ID:	1858434   Click image for larger version
ID:	1858435   Click image for larger version
