RCU Forums - View Single Post - Prop Mounting
Old 03-05-2013 | 01:31 PM
jeffEE's Avatar
jeffEE
Default RE: Prop Mounting
You could also try a 3 blade prop for a bit of ground clearance. Try an 11 x 6 ( or 8) three blade and see if that gives you more room. If you are flying off grass, you really need the room, the grass has a way of grabbing props.
