RCU Forums - View Single Post - Prop Mounting
Old 03-05-2013 | 01:56 PM
GaryHarris's Avatar
GaryHarris
Default RE: Prop Mounting
ORIGINAL: jstyle13
Well it sounds like an order for a reamer is upcoming. Thanks for the replies. Another question now. One of the props I messed up earlier I drilled out and put on the plane for balancing purposes only (putting everything on and in position to balance before I cover). With the tricycle config on the Kadet LT40 and the 12x6 prop I only have like 3/4''-1'' of clearance from the tip of the prop to the ground. Is that cutting it close? Should I go for the 11x8 that Saito says the 56 will swing? Kinda scares me only have an inch of clearance between the prop and Terra Firma.
Thanks!
Josh
Josh, I have 1 1/2" on my LT40 build right now with a 12x6 prop. I think your cutting it a little close. Just go with bigger wheels. Maybe 3 1/2" on the main and 3" on the front.
