RE: Prop Mounting
I don't see what difference it makes how you size the prop to the shaft, the only thing your doing is centering the prop on the shaft. Once tightened against the drive hub that turkey isn't going anywhere except around and around...
Greybeard... thanks for the tape tip, I can see how that'd work just fine.
