RCU Forums - View Single Post - High wing loading on Stik with a wacker engine??
Old 03-06-2013 | 05:19 AM
coralcape
Default RE: High wing loading on Stik with a wacker engine??
I modified an Ugly Stick 60, with 4lbs of lead weight on the CG. The idea was to learn to fly a plane with high wing loading. I had recently finished a P-51 with a very high wing loading and used the Stick as as a learning tool. Good results, Stick took it with no problem. Good luck, red
