RCU Forums - View Single Post - Prop Mounting
Old 03-06-2013 | 08:30 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Prop Mounting
Using the the taper reamer technique is the same way one would open the hole in a servo arm with a #11 blade from both sides carefully. That also is a good technique that results in a less sloppy clevis or S' bend joint.
The bottom line is use what ever tool you may have and yes I have both taper and fractional/metric step reamers and use both.
As I stated most do not bother with the APC prop centering rings and I offered that just for information.
John
