RE: which engine for which plane?
Engine problems on the Stik and you can float it in right to the ground. Engine problems on the Sportster and you can float it for a short period of time before it stalls. That plane needs to be flown in to land compared to the Stik. It's not bad but there is a difference and if this is all I had to work with I'd put the stronger engine on the Sportster.
I'd rather have an overpowered Stik (I have a few) as that will be more fun in my opinion and you could fly the Sportster with the weaker engine but I wouldn't do it. LA engines are good for trainers and Cubs.
