which engine for which plane?
My Feedback: (9)
GA
I have an o.s .46 la and an evolution .46nx and I'm not sure which plane would be better suited for which engine "big stik .40 and super sportster .40" Any thoughts?
My Feedback: (9)
GA
ORIGINAL: Granpooba
Put them in a '' Twinstar ''.
. Still not sure what to use where, any more input? I was thinking evo in the stick but you guys know more about this stuff than me lol.
My Feedback: (9)
GA
ORIGINAL: flyinwalenda
Higher wing loading on the Sportster than the Stik. The LA is a weaker engine than the NX given both engines are in good shape. I would put the NX on the Sportster and the LA on the Stik.
Engine problems on the Stik and you can float it in right to the ground. Engine problems on the Sportster and you can float it for a short period of time before it stalls. That plane needs to be flown in to land compared to the Stik. It's not bad but there is a difference and if this is all I had to work with I'd put the stronger engine on the Sportster.
I'd rather have an overpowered Stik (I have a few) as that will be more fun in my opinion and you could fly the Sportster with the weaker engine but I wouldn't do it. LA engines are good for trainers and Cubs.
My Feedback: (9)
GA
Nothing conflicting at all. You are missing the point . You asked which engine would be BEST for which plane. Either engine will "fly" either plane BUT the better engine should be put on the plane that needs it most to keep it in the air, not because it's the most fun.
My Feedback: (24)
CA
The Stik has a wider flight envelope, including 3D and would be a blast with the higher power engine with the right prop.
The Sportster would benefit from more scale like flight. While it may not glide as far as the Stik, it still will glide very well with the lighter LA engine and cowl.
You end up with two dissimiliar planes for variety...
