Have been working on extending my motor mount spacers today(machining) and painting the servo cockpit cover.. Ran out of dowl and had to run arround to find more aluminum rod..Hope to get the balsa spacer glued and glassed on the front of the cowls; tomorrow so I can get it primed . I am reduceing the spinner from 3.5 inches down to 3.25 inches. will try and get a photo posted. Made the mount 1mm longer than needed so that I can do a final trip once the cowls are done. Man this is as bad as building from scratch !
Oh by the way... your work bench looks as bad as mine and I thought I was the only one that worked like that ...
