RCU Forums - View Single Post - motor timing question
Old 03-12-2013 | 05:41 PM
*delete M i k e u p delete*
Default RE: motor timing question
Well, i would lower timing to 10 degrees and put a bigger prop on. 4400kv with a max voltage of 7.4 gives you no room but should use a smaller boat and a big prop. You did mention that all was cool after running with no speed increase.
