RE: LADO door servo setup issue
The tygon is over the shaft, in between the collar and the black case of the actuator. When you install the setup, fully extend the shaft and that will establish your mounting point with door open. Next simply close the door and when it gets close unplug the power and adjust the collar and tygon stop. The tygon acts like a soft stop and keeps the motor from locking up.
