 LADO door servo setup issue >
Old 03-10-2013 | 07:36 AM
757Driver's Avatar
My Feedback: (90)
Default LADO door servo setup issue
I am installing a gear door linear servo on my gear doors. Upon testing them they worked great on 4.8V servo tester.
When I used the airplane power 6.5V A123 the motor didn't amp out as quickly and ripped the mounts off the airplane and destroyed my work.
Is it possible to have the motor amp out at a lesser value? If so, how? I wondered if I could install a resistor bud didn't know what size or value. I'm not IEEE that's for sure. []
Old 03-10-2013 | 12:57 PM
Default RE: LADO door servo setup issue
I have done several testing myself also and broke my door...They give way too much torque, so you need to have a perfect mechanical set-up without any binding at the beginning and end of stroke....
I sent an email to Peter at altecare about the problem a couple week ago, he was supposed to as Lado what they can do...i did not got a reply back yet....They really need a programmable torque limit, but i think, encoder is the only ''safe'' way....
By the time, i'm planning to go with firgelli only, with thoose units, you can adjust both stroke end the way you want, exactly the same as it was a servo....
Alex
Old 03-10-2013 | 02:30 PM
mr_matt's Avatar
My Feedback: (10)
Can't you just put a wheel collar over the actuating rod? That will current limit it :-)
Old 03-10-2013 | 03:21 PM
I asked this question when i met lado at jetpower. They said i could return mine and they would de rate them to a lower torque. Ive yet to do that so Im not sure how successfull it would be.
I had thought id just put some tygon, secured with a drop of cyano on the shaft and see how i got on.
Old 03-10-2013 | 05:02 PM
757Driver's Avatar
My Feedback: (90)
Did tygon and a 3/16" wheel collar. Perfect!
Old 03-10-2013 | 05:56 PM
Guillermo Ibanez's Avatar
Send pictures please
Old 03-12-2013 | 01:39 PM
757Driver's Avatar
My Feedback: (90)
Pic for you. I used clear tygon and its hard to see.
Old 03-12-2013 | 06:40 PM
Thank you.
Where is the Tygon? Between the clevis and the actuator?<br type="_moz" />
Old 03-12-2013 | 06:55 PM
757Driver's Avatar
My Feedback: (90)
The tygon is over the shaft, in between the collar and the black case of the actuator. When you install the setup, fully extend the shaft and that will establish your mounting point with door open. Next simply close the door and when it gets close unplug the power and adjust the collar and tygon stop. The tygon acts like a soft stop and keeps the motor from locking up.
Old 03-13-2013 | 06:51 PM
Got it.
So when you plug the power again, the motor start to spin again until it stops, but instead of breake the hinge, the collar will compress the tygon until the motor reach its designed stop point.
Isn't it?
Old 03-13-2013 | 07:42 PM
757Driver's Avatar
My Feedback: (90)
The motor will stop when it reaches its amp limit.
