RCU Forums - View Single Post - Insight RC Remora F3a bipe
Old 03-13-2013 | 08:17 AM
  #75
MTK
Default RE: Insight RC Remora F3a bipe
ORIGINAL: RC_Pattern_Flyer
BTW, I am covering this plane with Balsa USA solarspan, antique.
It is awesome to work with, goes around curves with ease, tighens up nicely and it adheres nicely to the structure.
Chuck
I wish you guys luck with all those balsa stringers. Carbon tubing might have helped keep wood stringer breaks to minimum and helped remove some of the structure
Don't know the weight of solarspan. Sounds like it has the adhesive built in.
Polyspan lite adhered with balsalock might be lighter. Balsalock is water based and can be sprayed or brushed. I also have some other great water based spray on adhesives that are heat activated when dry. Contact me direct....
Many Free-flighters do what Dean suggested, 2 layers silkspan. Some free-flighters change the technique and apply lite polyspan first and then come over the top with coloerd tissue such as Plyspan Esaki. Builds into a very light but stiff-strong structure that is puncture resistant. Polyspan must be preshrunk with heat before the esaki. Look in any Free-Flight websites for supplies
