ORIGINAL: Rustytrax
#25 fitting the fuel canisters was frustrating since the cut out is larger than needed and the fitment is very loose.
# 26... anyone building this kit I suggest you attach the tie down loops before the initial hull coat goes on. I usually spray all the sprus first the clean the contact ares but these are so small it will be easier to spray then on the upper.
#33 the turret will need some sanding and filler to smooth the joining lines.
#41 the rear deck and hull will need a small bit of compound to close the gap. Possibly shaving some from the screw bosses of the rear plate can be done instead.
Almost done!
pics of yur build......please post pics!!
