ORIGINAL: mr_matt
Chuck can you mix DBC and deltron clear (activators, reducers, etc.) with Matrix and vice versa?
Also how can you find out who sells it? Matrix does not seem to have anything online that tells who their jobbers are.
Matt I do use the reducers....note that Matrix MR895 is closer to DT885 at least works that way down here in the heat. DBC is Deltron
and the Matrix match to it is MPB which includes all the colors and the Xyrillic pearls. I also like their epoxy, excellent adhesion and
easy sanding, compare that to DP. 2021 still the favorite of the Delton line though, but you won't be able to tell the difference on the
models.
Found one jobber in Burbank at
http://www.stateautomotivepaintandsupplies.com/
Chuck
Call them and if they can't help you they can tell you the local jobber.
