RE: New Evolution 10cc gas engine
I don't quite have low end dialed in but for those following the<div>Telemetry debacle and if you have experienced TM1000 failure to</div><div>Send the cure is a ferrite core that snaps over a single coil of the RPM</div><div>Lead as close to the white connector end as possible. Managed two flight this morning </div><div>With solid data. I will add that the best position for the telemetry</div><div>Antenna is vertically poking out the belly </div><div>Of the plane</div>
