ORIGINAL: netdudeuk
I had one and it was easy enough to fly but I'm not sure that, as a low winger, you can even start to think that it will self-right.
thanks for th information, I have other planes that are low wing electric and they seem to fly much nicer , they are more stable and like you said maybe they wont right themselves like a high wing yet this PT 19 is just a different bird , it yaws, it tip stalls and I have to input a little right rudder to make it fly normal even with the engine prop side thrust that's built into the motor mount. I have seen some side shots images of the great plane version and my e flight , and the wing on a great plane version has much more dihedral, I was also wondering if I run a larger Dia prop now I have a 9x7 ,maybe a 11.5 x 6 would be better ,what do you think.
