ORIGINAL: flyinwalenda
No.
If the ailerons are set with no differential that can increase yaw. Try adjusting/setting the ailerons for differential .
If the tail drops in a turn then you need to add a little rudder....it's called a coordinated turn.
THE REFLEX , DOES THIS MEAN MOVE BOTH AILERONS UPWARD? ^^^^ OR DIFFERENTIAL where yo make the upward movement greater than the downward movement on the opposite aileron?
