RCU Forums - View Single Post - Seagull Gee Bee Z
Old 03-19-2013 | 08:27 AM
  #457
maneba's Avatar
maneba
Default RE: Seagull Gee Bee Z
Gas test has gone bad. I wasn't able to go over 6300 RPM with standard carburator. The temperature is much higher than using nitro.
Good low-end very stable (about 1000 RPM) but a not so good top-end and low thrust.
So i'm going back to nitro [:'(]
Today i've received the HUGE 5" Dubro inflatable tires.
They are a little bigger, in diameter, than the original and they weight a lot but the landing bouncing will be reduced.
Now i've an entire collection of tires to choose from.
I've uploaded another solution for the struts.
Tomorrow i'll begin the build.
Stefano
ID:	1864174   Click image for larger version
ID:	1864175   Click image for larger version
ID:	1864176   Click image for larger version
ID:	1864177   Click image for larger version
