USER COMMENTS, SHOWING THAT HACKER,E-F TORQUE AND HYPERION-Z ARE THE EXACT SAME MOTOR, AND ARE ALL MADE IN THE SAME FACTORY:
http://www.rcgroups.com/forums/showthread.php?t=359052
Hacker A20-22 L v. Torque 22T / 930
Dr Kiwi:
" ...For these two motors there is nothing in it. They are different colors, but that's about it!
Do you want to view the world through "Rose-colored" spectacles (Torque) or do you prefer the "Royal Purple" (Hacker)? ..."
10Thumbs:
"...This and your other Torque vs. Hacker tests seem to indicate that these motors are probably made at the same factory and have just minor differences in construction ..."
http://www.rcgroups.com/forums/showthread.php?t=1159299
c/f:
" ... Hyperion was manufactured in same factory as Hacker and Tork motors ..."
http://www.rcuniverse.com/forum/m_51...tm.htm#5155039
Hacker A30-28 S vs Torque 2830T / 1095
Ryguy:
"They're the same motor basically. If I remember correctly they're even made at the same factory ..."
http://www.rcgroups.com/forums/showthread.php?t=684590
Hacker A20 or Extreme Flight Torque 20
ImFly1234:
" ... To be honest with you, I think these motors are from the same factory..."
blucor basher:
"The Hackers and Torques are similar in construction, as noted. I think it's pretty well established that the particular factory which produces them does an excellent job and has the most durable outrunners"
http://www.rcgroups.com/forums/showthread.php?t=358646
Hacker A20-26M v Torque 26T/1135
Dr Kiwi:
" ... I have come under fire for suggesting that the Extreme-Flight Torque series seems to be similar to the Hacker A20's ... I can't say much about the quality except that the bearings and shafts look identical ..."
http://www.rcgroups.com/forums/showthread.php?t=671362
Hacker, Torque or Scorpion?
Milton:
" ... Hacker and Torque off same production line. If there is one thing I know to be a fact that is ..."
Also:
http://www.rcgroups.com/forums/showt...=487557&page=2 -Torque vs Hacker motors
