"ELE" BRAND MOTORS, AS LONG AGO AS 2005, WERE MADE BY SUNRAY OEM FACTORY
-WEREIDENTICAL TO HACKER -AND WERE SOLD AS A SEPARATE BRAND ...
http://www.rcgroups.com/forums/showthread.php?t=455766
Dec 2005 - ildo:
"... Brand New: ELE Brushless Motor EA20-20L / KV 1022 ..."
" ... Specs: Weight: 56g; Diameter: 28mm; Length: 21mm / 27mm / 31mm; Shift Diameter: 3mm
(NOTE: every single spec of this ELE EA20-20L-identical to Hacker A20-20 L motor -andELE were also supplying S, M and L versions)
http://www.rcgroups.com/forums/showthread.php?t=489218
searching for the Hacker A20-20 clone = ELE A20-20L turns up nada
http://www.rcgroups.com/forums/showthread.php?t=545421
Has anyone tried the "Hacker-Compatiable" motors?
http://www.rcgroups.com/forums/showthread.php?t=443607
Brand New: ELE Brushless Motor A20S-34 / KV:1500
ildo:
"... this motor is the same as Hacker's motor ..." ( !!!!!!!! )
-So it is by no meansa new occurence, that the Sunray OEM factory has made motors under different brandnames.Even in 2005, they had at least 2 OEM customers for theirmotors-Hacker andELE ...
