ORIGINAL: clockguypete
Hi Stephano, nice cradle! About engine position, all I can guess is by mounting the engine horizontally, you keep the carberator closer to the center line of the fuel tank. That ASP 1.80 fs engine is about a pound heavier than a saito 1.80, so your right, mounting it horizontally throws a ore weight to side of the plane. You could help compensate by installing battery, receiver, etc on opposite side of fuse to help balance.
Is the same thing i was thinking. I've to put everything on the other side. Rx 2100 2s mAh life battery, 4500 1S nimh battery for the glow-plug, RX and other.
ORIGINAL: mbgbe696
I like your cradle. Great job, mind if I copy it?
Why not? Down here you can find the original project made by a friend of mine to do this cradle that i converted.
[link=http://www.baronerosso.it/forum/attachments/aeromodellismo-progettazione-e-costruzione/263330d1361784276-portamodelli-portamodelli.dwg]dwg file[/link]
[link=http://www.baronerosso.it/forum/attachments/aeromodellismo-progettazione-e-costruzione/263331d1361784288-portamodelli-portamodelli.pdf]pdf file[/link]
[link=http://www.baronerosso.it/forum/attachments/aeromodellismo-progettazione-e-costruzione/263908d1362218219-portamodelli-portamodelli.zip]dxf file[/link]
