RCU Forums - View Single Post - Mods on a redcat
Old 03-23-2013 | 03:21 AM
nitrosportsandrunner's Avatar
Default RE: Mods on a redcat
The motor will bolt right in.
The stock pinion gear however will not fit on the vxl motor. Stock motor has a 5mm shaft, vxl motor has a 3mm shaft.
Other than needing a new pinion gear, its an easy install.
How old is your stock motor? It may still be under warrenty. Even if its past the 90day warrenty, redcat also has a replacement program that could get you a stock motor at less than retail cost.
