RE: adding flaps to an arf
If the trailing edge of the wing is a plywood secondary spar (see photo), can the robart hinges be installed directly? Or do I still need to glue a piece of balsa block behind it? I can't really get access to the inside of wing unless I start cutting into the sheeting.
