RCU Forums - View Single Post - New Evolution 10cc gas engine
Old 03-26-2013 | 09:37 AM
  #1074
rcrobby82's Avatar
rcrobby82
My Feedback: (14)
Default RE: New Evolution 10cc gas engine
I got my engine mounted up and plumbed up. I am using a 6 oz tank since it fits better than the 8 I had laying around. I took the muffler apart and cleaned everything with alcohol and siliconed it up as well. The plane will finish out at about 5 Lbs 2 oz when done. I still have to attach the ailerons, elevators ect., and install all the linkages and servos. TheIgnition is mounted in the wing LE and is routed through a grommet for a clean install. The plug wire should be the only indication that this is a gasser.
Hopefully it will balance and 3D
ID:	1866802   Click image for larger version
ID:	1866803   Click image for larger version
