ORIGINAL: dce21b
Could someone tell me the best way to set up my throttle linkage for my LT 40. I am using an O.S. 46 AXII motor. I had it set up using one pushrod through the firewall with bends to the throttle link. This was causing a lot of binding and I didnt like the way it was.
I have seen some different set ups around using ball links and four stroke setups but still am confused and would like some suggestions as to what the best most reliable setup to use would be.<br type=''_moz'' />
I always use cable pushrods with ball links for the throttle. You won't have any binding and it is always smooth. I never built the LT-40, but I remember the Kadet Mark II used a cable pushrod.
