RCU Forums - View Single Post - Kadet LT40 throttle linkage
Old 03-27-2013 | 04:24 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Kadet LT40 throttle linkage
You are welcome DCE and thats just something to consider for the next one. Sometimes what can help when using the standard mounting of the throttle servo that may require a double bend is to try the piano wire pushrod for the throttle anyway if stock setup is to stiff. The very thin piano wire since it is still a very loose fit in the housing that is provided and it will often still work better than even the stranded flex cable.
John
