RCU Forums - View Single Post - Evolution 40 trainer engine
Old 03-28-2013 | 06:27 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Evolution 40 trainer engine
ORIGINAL: gliderguy100
So after a 24 hour soak in glow fuel I tried the popsicle stick trick and lifted the cylinder liner out with ease. From there the connecting rod, piston, and crank shaft came right out. Thank you Dennis and Sport Pilot for those tips. Now how do I get the rear bearing out?? I was able to get the front bearing out with just a few light hammer taps and a wooden dowel. But the rear bearing doesn't offer much of a lip or ledge to work aginst. How do I go about pushing this one out? Thanks again!!
Heat the engine case in the oven. 325* for 5-10 minutes usually does the trick. Smack the crankcase on a block of wood. Works like a charm.
