Here are two that you might consider if you have someone to help you maiden them and instruct you. The Easysport is the gentler of the two, but the Dazzler is docile enough if you set the throws conservatively. All of your components should work in either one.
<a href="http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDTM8&P=ML" target="_blank">www3.towerhobbies.com/cgi-bin/wti0001p
</a>
<br type="_moz" />
